CalifTom
I have a DOA G07 that is being used in my Joust U/R. I did a cap kit, flyback and hot replacement. I blew the F902 fuse on power up. After checking all of the recent component installations for correct alignment, everything checked out. I did a search to see what would cause the F902 to blow and found this repair info. (I edited my post, the fuse that blew was the larger one F902)
http://www.pinrepair.com/g07/
I checked the HOT with the diode setting on my DMM and it reads 001 and beeps (DMM has diode test and continuity on same setting). When I disconnect the yellow wire I get 069 reading. If this sounds like the HOT is good, why is it showing 001 when the yellow wire is connected?
I also checked to see if there was any continuity between the case of the HOT. There is no continuity.
Does anything sound as if it is connected wrong?
What would you suggest I check next?
Because of my beginner status, could you please describe for such. Thanks.
