KenLayton
In Memoriam
You are in shutdown mode. Check the soldering of electrolytic capacitor c511 (47 uf @ 250 volts) just like you did on C107. Bad connection at C511 will cause shutdown.
Ok so I re-flowed and checked everything I could find that looked like it needed solder ect...
Getting somewhere as I now get a picture but it's bright and blurry and adjusting the flyback up or down has no effect.
I am now able to adjust the B+ again and got it to 120 with the pot all the way to the right.
Should I still remove X701?
Really appreciate all the help guys.
