G07 Fixable?
JoeB1355
Seymour, Tennessee
So I have 2 G07's. I caped them both, adjusted, tested and now they both work
one monitor has lots burn, not the greatest color doesn't look that nice
the other tube looks good but has a big color blotch that incorrect
pictures attached? is the tube just toast? can I fix it?
other than the colors the focus etc all look great and little burn
If it can't be fixed anyone in the Harrisburg PA area have a decent G07 tube cheap they wanna part with or a whole dead monitor with a good tube?
PLUG: Alos looking for any Missile Command parts
Or trade stuff?
couple hantarax chasiss (1 complete, 1 for parts) and a
couple wg 4600 chasiss (again 1 complete and 1 for parts)
I can't remeber if the complete ones work -- best to assume broke
4 omega race board sets - most junk board for parts 1 set did play blind and has a new set of ram on it
omega race transformer and mostly complete wiring
omega race filter assembly
omega race liner power supply board
2 dynamo 1943 control panels with joysticks and wiring may be missing a button or 2 -- one yellowed and other with home made paper overlay...
Midway coin door (no frame)
Ikari warriors board set -- never tested
Looks like the monitor with the color splotch just needs to be degaussed.
I'm glad that trick worked for somebody -- didn't work for me. :)
I ended up having to go buy a degausser that will probably get used 3 times in its lifetime.
Better
I bet a real degausser is better, but this seemed to work ok. I wanted to try it now and no idea where to get one that wasn't mail order, so I had to give it a shot!
I had the electric drill next in line!
Nope
Its plugged it. I was just fearing the worst since I got the monitor after in lay in a field outside for 6 weeks or more after an op smashed and burned the cabinets.
On the other hand it was pretty clean for a monitor after all the rain and wind!
