G07-FBO Help needed
shado667
New Jersey
Okay...finished my first cap kit this afternoon...went pretty smooth. I was putting everything back together and have two wires that I can't for the life of me figure out where they go...
First is the yellow wire from the dial labeled "screen" that screws onto the chassis:
Second is the black wire on the chassis next to the flyback (is this just a ground?).
Thanks!
Well, it's not necessary to remove that when doing a cap kit, not even if replacing the flyback.
but to answer your questions:
1) The yellow wire attached to the screen pot connects to the yellow wire coming up from the chassis right there near the yoke connector.
2) the black wire that is attached to a screw on the right wall of the chassis connects to the other lug on the screen pot....
Thanks for the reply. Like I said, this is my first restore so I'm learning the hard way... I had a suspicion that's where they went, but I just wanted to make sure. I'll be up early tomorrow soldering, then it gets powered on... Hopefully all will go well.
Again....I really appreciate your help.
