I picked up a G07 CBO 19" boardset to repair, but the only other G07 I have is a FBO 13". Is it safe to use the CBO boards with the FBO tube to verify that the boards are repaired and operating correctly?
13K4900 is actually a 4800.....and no, you can't plug a 19" Electrohome up to it.
19K7000.....maybe. This series came with two different monitor neck sizes. One is the same as the 19" Electrohome.....one isn't.....but.....even if it is the same tube, you'd have to swap out the yokes.
