G07 FBO 13 inch no neck glow
Evilslayer73
Montreal, Quebec, Canada
«hi everybody i have a big big problem with my monitor !! i mesure the voltage on the monitor it gives me 175 volts on both xo1 and «hot no hissing sound ,
i tnink its the flyback but not really sure
DO NOT measure voltage on the HOT!
Neck glow is created by the heater which is only 6.3vac and can be measured on the back of the neck board.
What seems to be the problem with your monitor?
the problem is i have nothing on screen no neck glow i have meseare the voltage on the big white resistor on the left side and the voltage is 175 volt:)!!!which pin on the neck i should measure... thanks for your precious help
i f eel no static too when i start up the monitor the fly back make no pop when im grounding it on the frame..
im newbie on troubleshooting monitor thats why im asking tro professional like you their advice:) thanks again!! ««««a big thanks from «canada !
p.s the problem i have is due to a shorting issus !! i have put the jumper wire sitatuted down of the chasiss the one of them was loose and i plug it in the wrong place i hear a pop and a burn smelly from the chassis
i hope i dont have totaly crapped out my board!! thats why i need help also i have change the hot and the voltage regulator witout succes
i need serious help!!!
I have no idea what you did with the jumper wire, but from you statement....it isn't good.
Your original problem was high voltage shutdown. You stated 175 volts at the big white resistor...that voltage is too high, and tripped the x-ray protection circuit.....thus creating high voltage shutdown.
Edward
Edward
also i have remove x 701 witout succes
i have trip the two jumper behind the chassis near of the flyback there is 2 wire jumper each side have 3 prong that comme out from the board me stupid i am i have put the jumper in the «h cent!!! on the second prong pouf the resistor r 507 have blown in 2 ....
maybe the board is totaly scarpped out i need advice on it
