Mattspad
So I found a tube that may work in a g07 fb0. Its an RCA 1988 tv the neck has 8 pins and the horizontal is 3.8 and the vertical is 14.4. Is that a good yoke for g07 or not? It's the 13" g07 and a 13" tube.
Not even close. G07 is high impedance.
Assuming you have the G07 that you want to swap the tube into, just check the G07 yoke out.
Dont have a g07 sadly...
