I have a solar fox cabaret that needed a cap kit (I thought)
so I capped it, changed the flyback, filter cap, pots, and fuses. the flyback is a used but working g07 cbo flyback.
anyway, the screen has too much red first off. when I make the adjustment to the pots on the neck board it does little to change.
When I adjust the bottom pot for the flyback, I expect it to go very bright or very dark. It goes kind of bright and shows lines on the screen as you'd imagine, but when you turn it allthe way down it just gets very very red, not dark at all. slightly darker maybe, but really really red.
The neckboard was cracked but repaired, and seems to be repaired just fine with the continuity tests I did with it.
Before I did the cap kit, etc. the flyback adjustment pots were acting exactly the same as they are now.
any ideas what the hell is going on?
