saltbreez
Where in the Sam H3ll is F901 on an Electrohome G07?
TIA,
Saltbreez
TIA,
Saltbreez
It is the small pigtailed fuse to the right the biggest cap on the chassis……
What game is it in?
Are you getting ac into the chassis through an isolation transformer?
Make SURE you are running it through an iso transformer....follow the wires back to it. If you do not use an isolation transformer you will most likely fry the rectifier diodes D901 through D904, or the voltage regulator…… K7000 is the same deal....
Are you getting high voltage? Ie the screen "crackle" when you turn the machine on?
That is classic high voltage shutdown… you will have no neckglow…
