Anyone know if Rat Shack has anything close that can work? It's not fun looking around the store and getting the hard sell for batteries or a cell phone!
You aren't going to find leaded fuses that you can solder to the board at Radio Shack. But, you can simply buy a chassis mount fuse holder, and wire it up to the board, and use a conventional fuse.
Actually I was surprised that rat shack had the correct size and amperage. I soldered a "blob" on the ends and snipped the leads off a resistor and soldered it to the ends. Worked out great. Now if it does not blow.....
I have read that replacing the HOT with an old flyback that the flyback sometimes fails. This time I replaced all the caps,HOT and flyback and my F901 was gone. Not sure if it was before I capped it or not. I was also told that when replacing the flyback and hot that sometimes you will blow F901. Sometimes its hard to win.
