Museum of the Game® & International Arcade Museum® Forums
Following RF's flowchart, I get to the point where it states to check R1 (see line I traced onto it). I recapped the then dead chassis, including the filter cap, about 1 month ago, using an APAR kit. The flyback was also replaced.
When I check R1. the leg closest to the CRT is 108V DC, and the other end of R1 is 168V DC. I am unsure where to start looking next since none of the conditions at the point in the flowchart that I reached are met, because the input leg of R1 is HIGH at 168V (with the output side being low at 108V), while the chart only makes next suggestions based on if the input voltage is OK, 0V, or Low.
Any suggestions?
Thanks!
