andrewuts1
I recently recapped a 19" G07 and the screen still looks very dim. You can barely see the screen unless the lights in the room are completely turned off. In the dark the picture is fine. I have recapped several chassis and have never really had this problem. I adjusted the flyback with limited change as well as the color pots.
The only thing that is unusual about this chassis is that the suction cup thing that attaches to the tube itself is loose and doesn't look like it makes a snug fit. The two little prongs are inside the tube but I believe the suction cup thing is just not pushed alll the way down on the end. Could this be causing my problem? Or is this a tube rejuevenation issue I've heard about? Thanks, Andy
