G07 Dead...
Fudd
Kalamazoo, Michigan
had a fully rebuilt g07-cbo die a month after i did the work to it.....here's what i know so far..
both fuses are good
new hot-vr-flyback-caps
everything in 900 series tests fine
pulling x701 does not bring back to life
x901, x902 replaced
swapped filter cap - no change
getting 50v at both ends for R901
start touching up all the solder. whats your B+, is there any staic when you power up, did you try turning up the screen all the way to see if you get raster?
Dead flyback? Bad tube? Try swapping the cahsis to another tube.
