G07 collapse help
shilmover
Washington
the G07 in my System I collapsed today. I was testing the control panel when the score on the top collapsed. A few seconds later, I watched as it collapsed from the top to the middle (as you see in the picture).
I know that the horizontal coil is broken... Any idea where to start?
one of the vertical output transistors pooped the pillow on you, but try resoldering the pins on both of them first ( cant recall the trans numbers but they are the 2 mounted on large aluminum heat sinks, mounted about mid board)
Thank you...
You know I have roughly 6 G07 donor chassis, right?
And a 19" monitor that Saltbreez left here for you.
I did not know about the donor chassis... good to know. I know about the 19" monitor... Need to find out when I can come up to get it...
Resoldered them... no change.
I will need to find replacements for them. Dokert, I may head to Fry's to try to find them unless we can meet in the next day or so...
