G07 cbo ?
lextek1
Friendswood, Texas
Somehow the smoke was let out of the flyback transformer. I have a rebuild kit for it and replaced the flyback and noticed there was no core in the width coil. went to unsolder and found a bar across the two posts with the resistor symbol on the board. Replaced the width coil with a Bob Roberts kit unit that has an adjustment core. Should I replace the soldered bar across the two posts again? Seems that was shorting the coil to a set value..... Confused as usual....
Thanks for the help!
Don
Leave the bar off? OK thanks... Would it be wise to replace the HOT. This flyback burned two holes in the case under the iron bar that goes from top to bottom on the side. Is this unusual or just something that happens?
Probably due to the bar being on there.
If the monitor works, then you can leave the HOT alone - unless you just feel like changing it. If it doesn't work, you might as well replace it as you look into it further...
Replaced flyback and width coil. Was blowing F902. Found HOT shorted to case and replaced. Flowchart takes you in another direction for F902. It seems F901 is the high voltage side of things???
All is good and Centipede lives a little longer!
