G07 CBO -T501 & T503 test
eh97ac
ON, Canada
Is it possible to determine with a multimeter if T501 T503 are in functioning order?
If so, can you let me know how.
No. You can check to see that it's not open, but not if it's working properly.
Now, if you get a ring tester, then you can test them...
I took T502 off the board and get continuity when I test the side with 2 legs....good?
Probably. What issue are you having that you feel the need to test them?
