Never messed with monitors much but I recently got a super pac-man and it will usually not come up. It will play blind just fine and when it does show up on the monitor (takes many times of turning it on before it does) it will stay on for long periods of time and the picture looks decent but maybe a little of a slow wave to it. The dc voltage on the white wire on the large resistor nearest the CRT reads 120 volts when the monitor works right and comes on. When it does not come on the voltage reads 145 ish (fluctuates) and the monitor makes some kind of cycling sound like its trying to come on. You can hear it near the flyback. I also noticed a cobweb near the flyback that pulsates back and forth at about 1.5 sec intervals when the monitor tries to come on but doesn't. I was thinking about just throwing a full deluxe rebuild kit on it and seeing if that does it but does this sound like a failed component or maybe a cold solder joint on something?
