I have used all the caps but 2. The 2 left are 100uf 25v. The paper that came with the kit says that they should be 220uf 25v. Will the 100uf work?
I'm suspecting something to do with the curl mod. Did you perform the curl upgrade? The caps involved are similar values to the ones you are referencing.
http://arcadecontrols.com/BBBB/g07notes.html
Wrong value for the curl mod friend.
Where did you buy your cap kits per say?
