G07 cap # C520 direction?
gameguy1957
Mobile, Alabama
Does the negative on cap # C520 face the flyback side like most of the other caps on the G07?
The cap I pulled is not clearly marked and there are no markings on the board or cap maps I've found that show the orientation on that particular cap.
Thanks,
- JM
C520 is bi-polar so direction doesn't matter if you're using the correct cap. Look closer at the cap you pulled and somewhere on it it should say 3.3uf/50v BP
