kelleyphd
Did you figure out the problem? I am having the same problem.
Daniel
Daniel
shorted diodes?
I have a new flyback and hot and f901 blows everytime.
Daniel
I think a short in the deflection circuitry can cause this if fusible resistor 401 (FR401) has replaced with a non fusible resistor.
I took a look and the FR401 looks correct. It is the white rectangular type - 68 ohms, 2 watts. How is this tested?
just like a resistor
can't test R908 in circuit, need to lift one leg
the big white resistor that the VR hooks to...
with nothing hooked to it i get around 220 ohm
with the white wire hooked to the VR i get about 30ohm
with all wires hooked up properly i get about 10-15 ohm..
i checked out a couple working chassis i have here and i should be able to measure 220 ohm with everything hooked up...this has got to be causing my short, but what?
the VR tests good, diode setting, red to case of VR and black to frame i get .463 and is brand new..
got the VR figured out, wiring was causing some problems, got a good 220ohm on the white resistor now....fuse f901 (small fuse) still pops......not fun
