G07 blows F901 after tube swap
Scott C
Donor 3 years: 2022-2024
Missouri
Had a working G07 19" monitor and decided the Shinobi burned-in tube had to go. Found a TV (made in 1980) with a chassis and neckboard that looked an awful lot like a WG49xx series chassis (the neck board is dead on). Knowing WG49xx and G07 tubes are the same prompted me to swap it into the G07.
Upon power-up F901 blew instantly (F902 and the HOT both test fine afterwards) and I heard just a faint crackle (HV) before it did. The degausing coil was plugged in. My thoughts are:
- The tube is not the same as I expected and not compatible. The G07 tube is a Rauland 19VMJP22 and the TV tube is an RCA, but I can't find any identification numbers any where on it. The G07 Rauland tube is an 8-pin and the TV RCA tube a 10-pin (which means the chassis should simply ignore them, I have been told).
- I did not swap yokes, since I have had good luck on the last couple of tube swaps (G07 & WG49xx series). The yoke wires had a slightly different pin connector, so I had to break the plastic holder. Said another way, a G07 has 4 yoke wires and there are 5 pins on the chassis it connects to. There is a spacer between the larger red wires and the first of the 3 smaller wires. The TV did not have that spacer, so I broke the larger red wire away from the others. I am sure the red wire was plugged in correctly on the G07 chassis, but have no way to verify if the other 3 were swapped around. However, even if they were, it would only mirror or flip the image (perhaps not, see below).
- The G07 chassis was capped within the last year or two, but the flyback looks to have some age. Could it have gone during over the last 3 weeks, since the last time it was used? Sure, but I have not doubts, but admittedly I didn't test it before doing the tube swap (my bad).
- The TV worked a year ago when I turned it on and chances of just the tube going bad during that time is very remote.
Alright, after typing all of this up it occurred to me I never tested the vertical impendence of the existing TV yoke. Well, it turns out the original G07 yoke is 55 ohms (vertical) and the TV yoke is 30. Weird number, but way too far off for it to have made a good picture. Further, I noticed the TV yoke has one of the vertical and one of the horizontal wires swapped in the yoke connector that attaches to the chassis. That is probably why F901 blew.
I'll swap the yokes and replace F901, plus test some other items and see if that solves the issues. Ah, well... an exercise in bad practices... :)
Scott C.
If you crossed the yoke wires (put a vertical on horizontal....and vice-versus)....you took out more than a fuse.
Also, the vertical windings of a yoke arn't near as important as the horizontal. I agree 30 ohms versus 55 ohms is too much of a difference to give a "good" picture. If the horizontal winding is drastically different.....it can take out a bunch of parts.
Edward
You should have swapped the Electrohome yoke to the new tube. Electrohome's yoke wiring is different than everyone else. The connector is different and so are the wire colors.
See page 4 of this document:
http://arcarc.xmission.com/PDF_Monitors/Eygo chassis Replacement for G07.pdf
The Electrohome yoke wire colors are:
Red & White = Horizontal section
Grey & Brown = Vertical section
You have probably damaged the Electrohome chassis from incorrect wiring of the other yoke.
I agree and suspected that. :( I replaced the fuse this evening, installed the G07 yoke, and fired-up the monitor. The good news is it turns on and I have high voltage. The bad news is it also have vertical collapse (nice blue line in the middle of the screen). I'll start digging through the troubleshooting chart to see what else I fried.
Scott C.
There's a fusible resistor in the vertical circuit of the Electrohome. You probably blew that resistor.
Thanks for the suggestion and you mean FR401. No, I checked that and it's reading 68 ohms as normal. I'm checking the other things the troubleshooting charts suggested, since something in there has to be bad. I may just shotgun that whole section, since the chassis looks both crispy and corroded in that section.
Scott C.
