G07 b+
jbk
Donor 4 years: 2011, 2013-2015
rivesville, West Virginia
Where are the test points to check the B+ voltage? I have searched the forum to no avail. I'm a monitor newbie and am learning on the fly.
Attach the ground lead to any metal point on the chassis, attach the other to the far leg of the huge resistor. The resistor in question is the massive white one attached to the metal chassis on the left side (looking at the monitor from the back) it looks like a white ceramic brick about 2 inches long. You need to attach the lead the leg that is closer to the tube.
Do you set the Multimeter to AC voltage ? I'm looking for 120 volts coming off that big white resisters leg ?
