matthew180
I recapped a G07, replaced the flyback, and the HOT. It worked fine for a while, then went out. I realized I did not do the B+ adjustment after recapping, but now it keeps blowing the smaller 1.25A fuse F901.
I lifted two wires (W416 and W420) that provide B+ to the rest of the monitor, basically isolating the main B+ regulator circuit, and now the fuse does not blow and I can measure the B+ output. B+ is pegged at 174VDC and is not adjustable via R909.
Does anyone have any suggestions as to what I should check?
Thanks,
Matthew
Thanks,
Matthew
