mixinguiness
So I just recapped a G07 that had quite a few problems. I set the sync with a working Sky Shark board. Everything looks great with that board. When I swap it over to a 60-1 the picture rolls from left to right and displays a split image. (You can see everything double on the screen)
I have checked and rechecked everything in the Sync Circuit, replaced the 2 resistors that were wrong from the factory, 120vdc is perfect, fuses are good, caps are new, scroll mod done.
I have also verified that the board is set to 15.7Khz and tried a second board as well (Tried a 48-1 and a 60-1)
I have also tried all different settings for the sync wire (Currently on J2/3) and adjusted/changed the pots to no end.
Update: Just replaced Flyback and HOT with no change.
