G05802 Chassis mounted Transistors order?
Malice95
Howell, New Jersey
I have two G05802 monitors I am working on.
I replaced the chassis mounted transistors on the one
and then went to replace the other and realized they are
not in the same order on this monitor. Somethings wrong.
Probably the reason why the one chassis board was blown up.
What order should they go? Starting at the front of the monitor
tube at the one all by itself working backward.
Yea I found um.. I need to look at the drawings more carefully.
I assume because it didnt show a side view.. Makes an A$$ outa me..
