BobsterD
Do yourself a favor and change all 6 pots.... I've capped many and the jitters will remain until you replace the pots. Just a test... try adusting the pots while it's on and you'll see how it affects the jitters.
Maybe I missed it,but did you replace the pots on the deflection board also? Mine was jittery and new pots fixed it.
Keep looking... I'm not sure which G05 you have, but there should be two X pots and two Y pots (on -801 the Y pots are R636 and R631, on -802 they are R600 and R602).
DogP
Dang...I bought the "G05 pot kit" from Bob Roberts and replaced them all. Fired it up and looked great until it warmed up. Then started jumping again. Any more great ideas out there? I'm stumped.
Have you tried a known working 2nd game board?
I read once here on KLOV the capacitors on the game board can cause jumping
I read on Bob Roberts page that "big blue" can sometimes cause these kinds of jitters also so I replaced that. After about 2 and half games, the whole thing went nuts. Now I have random graphics garbage all over the place and the start buttons are flashing at about double speed. What the heck?
And no, because I don't have a known working board available at the moment.
The problem will stop when the correct part is replaced.
(Unfortunately I live overseas, so no good there)
Ok, I thought I should go back to the original thread and keep it here so I won't get confusing....
I checked pin 40 on the cpu with my logic probe and it's pulsing. This means the watchdog is yelling at the neighbor right? So I tied together the watchdog disable tab to the ground. Then the flashing start-button lights went dark. Everything calmed down and the screen is blank. Spotkiller is lit but only veeeery faintly. Not sure what any of this means. Does it mean anything to any of you?
I had something similar to this and it turned out to be the CPU, mine had a 6502, when in the Atari Schematics it was calling for a 6502A. Replaced that, and it worked....But your mileage my vary though.
