G05-805 Diode Replacemant
thebman80
Wallingford, Pennsylvania
Would the NTE505 Diode at Mouser (part Number 526-Nte505) be a decent replacement for the Original Diode VARO H1802 that was in the G05-805 monitor? I can see at least one instance in where it was used successfully. I just don't want to Damage my 13" monitor down the road. Since Bob Roberts is sold out and this one only costs like $6.00 instead of $15 I hope it would be a cheap substitute.
Mouser PDF
http://www.nteinc.com/specs/500to599/pdf/nte504.pdf
Diode H1812 PDF (should be the same as the H1802)
http://arcarc.xmission.com/PDF_Monitors/Electrohome G05_HV_Diode_Datasheet.pdf
Where I found it being used as a replacement. (bottom of page)
http://www.mcclennen.com/arcade/fixing_my_electrohome_g05_monito.asp
