g05-802 red light???
LUCKYMAN
Clifton Heights, Pennsylvania
I have a GO5-802. I tested it in my friends ASTROIDS cab and it works perfect and the spot check RED LIGHT on the deflection board is OFF...
Now when i plug the monitor into my battlezone (mind you that the PCB'S arnt hooked up cause they dont work) The RED LIGHT on the delection board is on...
anyone know why this would be???
That is what is called the Spot Killer.
LED ON = Spot Killer ON
The fact that you do not have working pcb's connected the monitor will basically go into a shutdown mode in order to not burn a focused "spot" in the middle of your monitor.
You will never have the spot killer go off if there is no boards hooked up. The boards send the X/Y signals to turn off the spot killer.
