bungy
I have a G05-802 that does not work, and a 19V2000 that does work. 19V200 is in an Asteroids Deluxe and the game plays fine, and I am troubleshooting the G05-802 with this cabinet. When I first hooked up the G05, the spot killer LED stayed lit, and there was no neck glow, all fuses tested ok. Jiggling the P500 connector made the neck glow, so I reflowed solder to all pins on all connectors (P100 pins, P500, P600, P700, P701). Now spot killer is still on and the neck glows.
Took a closer look at the fuses and some idiot had installed 10A fuses in all the sockets. I replaced the fuses with the correct values and now F102 blows when I power it up. DB100 tests ok. Cap kit has not been installed on this monitor. Chassis transistors are not shorted to chassis. Voltages at P600 & P700 seem to be ok. Not reading any voltages on the P500 connector except for pin 10 which reads 6.3v for the heater.
I have read the B&W X-Y FAQ, G05-802 manual, and 19V2000 manual but can't seem to figure out what to do now. Where should I go next? Is there a flowchart for the G05-802?
