G05-802 or V2000 - 13" vs. 19"
modessitt
Austin, Texas
I know the deflection boards and such can swap between the two models for the 19", and I assume the same is true for the 13".
What I want to know is - can the deflection board from a 19" be swapped to a 13" and vice versa? I'd think the HV may be different between the sizes due to the tube size and a need for more HV, but what about the deflection board?
I have a 13" that's missing the deflection board...
HV and deflection boards are the same on the v2000.I think the deflection boards have a couple different resistors on the go5's.The high voltage units are the same though.
Well, I just rebuilt a 13" V2000 at work today, and did a 19" V2000 last week, and noticed that the 19" has four 1u 50v caps on it, but the 13" had mylar caps in those spots. Dunno if that matters or not, as all the other caps and stuff were the same as the 19"....
