g3n3r1c
Permanently Banned
That does not make sense........
I have to review the schems again.........
Sense or not, it's working and looks great. Jimjaycee just left with a boatload of pics for confirmation. He'll post them soon.
This is very interesting since I have a 801 missing the hv cage. How much would something like this cast to have done?
You'll have to find a working 802 HV unit. The parts to do it are less than $10
Are those just as hard to find as the 801 unit?
I thought I'd try to make it a little more obvious exactly what the modification (diode+wire) shown on g3n3r1c's post with pics is actually doing. I hacked the original GO5-801 regulator schematic to show the modification and posted it here.
I believe that Jetusenet was rightfully confused by g3n3r1c saying that "pin 1 was 26.5V" because the modification clearly should have made that pin much higher, as high as +40V. Also, another member reported that either a faulty Q100 bottlecap transistor, or the incorrect one, caused the output to go up to +40V as well. This is a direct proof that the output from the DB100 fullwave bridge should in fact be close to +40VDC. With the modification, pin-2 should stay at the regulated level of +25VDC (or close to that) and pin-1 should be close to +40V which is ideal to supply the -802 HV box.
Alright, sorry for the delay.
Only one modification to the power board that I can find. There do not appear to be any modifications to the HV or Deflection boards.
I guess I should add a disclaimer:
If you attempt this based on the information I'm providing, do so at your own risk.
Lift the lower lead of L100 (side closest to the big heat sink)
Solder a 1N4007 stripe side to the lead you lifted
Solder a length of wire to the other side
then solder it to the collector of Q100
see pics for details.
Hopefully this resurrects a few 801's.
Post your successes/failures in this thread. I'm curious how it turns out.
Just a heads up, if one were to do the mod you outlined to a Issue 3 regulator PCB, one would be sending ~ +45v into the deflection PCB, (see pic).....
What issue regulator board do you have?
BTW, I tested this, (my mod), voltage-wise and I am getting about +45v (unregulated) going to the HV cage. I am not too keen on running it this way but will do until I can get the correct cage.
Jeff
How hard would it be for someone to reproduce the hv unit for a 801? I know there is someone making stuff to fix the lights for the neo-geo so could the place he has making the boards for that make boards for this or would the cost be to high?
