8bitPower
Thank you! I did this last year on an asteroids with a failing voltage doubler that was causing the monitor to bloom and do all kinds of weird things, it worked great. I was trying to find the site earlier today.
Sourcing components.......
Cap: HVCC203Y6P101MEAX
100pF @ 20kV DC
Diode: DD1800
Vr = 18kV
If = 20mA
Vf = 40v
Ir = 5uA
Max surge current = 3A
Since I am not an EE I would appreciate if someone could confirm this would function as expected.
Thanks in advance
Jeff
D901/902 = MUR2100EG
I never fire HV's up (intentionally) without the tube attached. But I would expect it to just arc to air if it were working.
However having no HV at all could mean any part of the circuitry driving the flyback is dead. The only way to know if the fly is bad for sure is to swap it into another known-good cage. But if you're getting nothing at all I would suspect the rest of the cage components first.
I have used these parts in many many builds without issue...... I am going to have to check all the components again to prove them out....
Thank you for helping out - it's good to be able to talk to someone with these problems.....
The tube is essentially the storage capacitor in the HV (rectified flyback output) circuit. Without the capacitance (and load), how can you be assured the voltage is correct?
I'd also never power up a HV cage without the anode attached (to the tube). Also doesn't seem safe to do so either.
