G-07 CFO: removing shield from pcb?
Sinistar
Donor 2021, 2023
Las Vegas, Nevada
Hi guys, working on my 2nd cap job now, and it's CFO. Very cumbersome compared to the EZ or CBO.
So there's this shield that sits on the board and protects the IC chip, there's also a few caps under there i can see i want to get to- but how do i remove the blasted thing? Is there a solder point i'm missing or do you just pry it loose?
thanks-
Jeff
on the cbo it was soldered on the back side.
Ok, that's good to know. Will have a closer look, so many solder points underand around it, might be easy to miss. Is there anything in particular to look for? Is it just an unlabeled point?
