Fuse wire placement
videodan
Donor 3 years: 2023-2025
Melrose, Massachusetts
In the next several days, I'll be replacing the 2 position fuse holder in my Galaxian. To double-check, I'd like to know what color wires go to what terminal. I'm not sure if it should go like this:
Orange Brown
Brown Orange
Just want to make sure all wires go in the right spot, figured it's better than guessing! Thanks!
Hey, any Galaxian owners out there? VAPS has a looooong list of Galaxian owners, so help me out! Thanks!
I think I'm forgetting something. Oh yeah, BUMP!! LOL
measure the AC voltage.
I don't own a cab but when I powered up that board it requires two different AC voltage right to the board. I think one is 7vac and the other is 10vac. Just check and make certain where each voltage goes. The higher voltage goes to the smaller diodes on the pcb and the smaller voltage goes to the bigger diodes right near a regulator and a large white resistor; If I remember right
I use a switcher myself with a computer hard/floppy drive plug so I can use either a switcher or a cab.
