Fuse value
dbpbandit
Oregon
I have a Williams "Aces & Kings" EM pin and I cant make out what the fuse value should be on the fuse block. It's the third one down from the top, I can make out the rest. I put an 7-AMP in there and it's working but I just want to make sure I'm not too high. The manual doesn't say and I don't have a schematic.
Thanks.
not sure exactly either but 7 amps is too high
try putting in a 1 or a 2 amp, if it blows then you know its too low
can't hurt anything as the fuse is the protection
Thanks, that's what I ended up doing. I ended up with a 3amp fuse, seems to be fine.
