Fuse keeps blowing on BK2000
navyav8tr
Chesapeake, Virginia
So this is my first SS pinball and second pinball ever so I am pretty much a novice at repairing and troubleshooting these things.
On the upper playfield I noticed the three jet bumpers not working, they lit up fine, but would not "bump". After some trouble shooting I noticed a blown fuse and replaced it. After another round of play, approx 35 minutes, the same fuse was blew again.
Where do I being to go about fixing this and figuring out the issue?
Thanks for any and all answers out there.
hello, congrats on your new machine, first place to start http://www.pinrepair.com/begin/index.htm a real life saver, you might have to hunt around on there to find more game specific info, what fuse is it that keeps blowing? the one under the playfield? its quite possible that a solenoid is sticking causing the amp draw to climb and blow the fuse, i would get a schematic for the machine so you can find the fuse on there and make sure its the correct fuse for that location. then look to see what runs from that fuse, that way you can hunt down your problem and repair it.
