xrayrox
looking for an awnser and I know you guys can help. when replacing a slow blow fuse can I use a higher voltage fuse as long as the apmerage is the same. if so is there a limit, can I use a 250v 15amp fuse to replace a 6v 15 amp fuse? what is the difference between glass and ceramic fuses? who knew there were so many decisions when it came to fuses.
