Fuse blowing Problem
onix
Wichita, Kansas
Hi,
I have a ring king that has been setting for a while it had a switching power supply in it. When i went to power it up it was dead, Well i got a new one and checked the cord which it had a bad spot which i replaced also. Well the 3a fuse blows in the fuse box coming out of the cord, It will come on for a few seconds and then nothing. Can any body help me or has this happend to you.
Thanks Tony
Hi,
Thanks Tony
Fist post:
*Welcome to KLOV*
first recheck all the wires to be certain they are wired correctly and make sure of where you plug that into. You may have plugged into where an isolation transformer goes.
post a pic of what it is we speak so we can help you more.
Also make certain the supply is set for 110 and not 220 but that should not blow a fuse.
