Fuse amp on mcr linear power supply board
dyno
Lower Mainland, Britsh Columbia
Can anyone tell me the amps of the F1 fuse on a MCR linear power supplu board, the one on my board keeps blowing and it is a 1 am fast blow but I think I found a schematic which says it is suppose to be a 3/5 amp slo blow. I just want to confrim before I put that fuse in.
I have 2 spares for my games and they both have stickers by the fuse indicating 3/8 slo-blow.
Rich H
Maybe that was my problem, the mcr had a 1 amp fast blow so I will put in a 3/8 amp slow blow and see what happens. Just want to clarify that it is a 3/8 slow blow amp or a 3 amp slow blow, don't want to put anyhting in to big.:)
That fuse actually changes from game to game....check the specific game manual. Most do use a 3/8ths slo-blo....I'm know Spy Hunter calls for a 1/2 amp slo-blo.
Edward
Awesome, thanks edward for checking your manual. I will pick up a 1/2 amp slow blow and see what happens, hopefully someone just put in the wrong fuse. Thanks!
Well I had a 1 amp slow blow fuse handy so I put it on the mcr power supply board to see what would happen. Turned power on and the 1 amp sarted to glow orange but before it blew the 5 amp fuse on the transformer assembly blew. I am thinking the problem is on the MCR borad and not the transformer assembly becuase when the mcr had a 1 amp fast blow it blew but nothing happened to the fuse on the transformer assembly. Does that sound right. I am going to test the diode at 106 becuase that is connected to the fuse and see if it is bad. If that diode is bad I assume it could be causing the fuse to blow?
Finally got to take a closer look at the power transformer assembly and the fuse that blew on there when I tried a 1 amp slow blow on the mcr power supply was part of the +12v circuit so can I assume the area that is causing the fuse on the mcr power supply to blow is part of the +12 circuit.
I had the same problem last week, blowing F1 fuse on my TRON. I isolated the problem to the SSIO board since it uses the 12v for the sound circuits, take the 2 ribbon cables off the SSIO board and fire up game and see what happens, you'll get a sound board error warning and pix will be upside down, see if fuse still blows. I swapped out the SSIO on my TRON and all is good, come the winter I'll try and find problem on orig board.
Rich H
The problem is on the either the mcr power supply or the transformer assembly because I disconnected everything else and the fuse on the power supply board blows.
