Funhouse Steps Gate not opening fully
Slim
Washington
I'm having the following problem with my Funhouse. The steps gate only opens about 1/2 of the way and when the ball goes down that path it will often get stuck behind the gate. Also, when it is supposed to close it will just gradually go to the closed position instead of snapping closed like I believe it should. Probably foolishly, I went ahead and replaced the solenoid but that didn't change the behavior. Anyone have any ideas on what could be behind this issue? Thanks in advance.
What pulls the gate up, usually a spring. Check if it has slipped out of position and not in the right spot to open the gate all the way.
LTG :)
