SpaceGuppy
About the playfield; I know the first couple hundred had the Diamond Plate; what other possibilities are there? I understand there's a mylar covered one - is this like a plastic piece or is it a clearcoat that's painted or applied?
Also, I have seen the display replaced by an LCD in one instance instead of the usual display assembly (which I think bride of pinbot uses as well.) Apparently the stick display goes bad - any comments on this?
Finally a game play question - how do you start Silly Mood?
