Funai crt tube....conversion...
SilverDuck
Minnesota
Picked up a Symphonic 19" crt tv with a FUNAI tube. The yoke wires were red/blue/yellow/brown. 8-Liners website says red/blue are horiz deflection, and green/yellow are vert. Mine has brown/yellow. I assume these are the correct wires for vert deflection? Anyway, they ohm out to 15.8 ohms. Does it sound like I did it correctly?
Ok..I have.....something....en route from Alva Amusements. They speak with a thick Spanish accent, but I think I have the correct chassis en route. Part #2620S Chassis for $59.95 + $14.50 Shipping.
Is this on par with the pricing they give everyone else?
You will find that you will have to cut the yoke wire and use new cable they send. Same as the video cable will need to be spliced into your current harness as the header pins are different.
Ok, the yoke connector was something I was wondering about. I assumed the video connector would be different.
So, they will provide the connectors for both yoke and video?
Thanks!
