FT: Konami 4-player cab for Midway 4-player cab
Paul Olson
Reno, Nevada
I just bought a NBA Hangtime board and control panel to use in my 4-player konami cab since mine has no control panel. The CP isn't an exact fit, so I figured I would offer the trade before I make it fit. Reno or close.
Paul, I just ran into the same issue. Did you go down the road of making your Midway CP fit on the Konami cab? If so, what all did you do? I am about to have to do the same thing...
I haven't done it yet, but it doesn't look like it will take much. The small lip at the top of the CP will have to be extended. I think I am going to just replace that whole piece with a larger one cut from aluminum. The back of the box will need to be extended so I can drill holes that will match the Konami mounting holes. I think I am going to try just adding a 1x2 poplar board across the opening to see if that will do it. I think I have one laying around.
If I get to this this weekend, I'll let you know how it goes.
I have both Pin Bot AND NBA Jams projects. :) It's possible that I could work out a deal for both if they could be moved fairly soon. I think you are to far away though.
