FS: Working vectrex with Sean Kelly multi-cart
komodo
Donor 2019, 2021
Flower Mound, Texas
I have a working Vectrex I purchased from another member on this forum a while back. It has an early model of the Sean Kelly Multi-cart with 35 games on it. Games are selectable thru a menu driven system. Menu is dated 1999 version 9. System works fine and is in very good condition with the exception of a spot on the housing towards the back that appears to have been melted with a soldering iron or cigarette. Highlighter on top is to give you an idea of size. It is available for $235 shipped anywhere in the 48 states.
Need to make more room in the house and this has to go. I have another Vectrex for sale that comes with 5 games in addition to the one installed on the system. Clean Sweep, Solar Quest, Bedlam, Webwars and Star Trek. The cabinet on this one is in better condition although the controller does not work properly. The controller needs to be cleaned or serviced as I tried the controller from the other unit on this one and the games all played fine. Repalcements can be found on eBay or other gaming sites. It is also missing the volume control knob. This one is priced at $140 shipped anywhere in the 48 states.
These units are a blast to play and a cheap way to experience vector goodness without all the hassles of a full size arcade game. There was a recent post by a fellow KLOV'r on these units. Check it out then get back to me quickly as I don't think these will last long.
Photos are here:
http://picasaweb.google.com/pat.danis/Vectrex?feat=directlink
You will note that the second unit shows a seam along the top where somebody (not me) didn't reassemble the unit properly after taking it apart. Should be simply a matter of loosening the screws and putting it back together correctly. Frankly, it never bothered me and I just never messed with it as I used the other unit.
Both units can be purchased for $350 shipped to the 48 states. Thanks
These are definitely great game machines to own - I have one with the newer 72 - 1 multicart. Great original games and newer homebrews. Someone should pick these up; lots of fun!
Let me know if you ever want to sell just that bad controller - I'll buy it as long as the price is right...
I'll probably keep the controller with the unit just so that it is complete. I need to sell these quickly before I change my mind.
