metahugh
Pictures:
http://gallery.metahugh.com/main.php?g2_itemId=3399
I rebuilt this about 6-7 years ago for my dad. He played it for a little bit (not many games at all) and it just sat there until he decided he no longer wanted it in his gameroom. So here it sits in my gameroom and I have zero interest in it. I state up front that I consider this a project game because it has a few issues. Let's start off with the bad:
1. Some of the drop target switches need to be adjusted as they are awarding points if you bang on the playfield
2. A few of the lights are getting stray voltage from somewhere making them partially on
3. The game will reset. I have not tracked down the exact issue but if you flex the right side of the CPU it starts to play again. The interconnect was replaced 6-7 years ago
4. The coin door need a new switch for the advance button to work
5. The backglass isn't in the nicest of shape
6. The 3rd and 4th player displays are having issues. The 3rd player display itself is fine (tested on player 1) but the 4th player display needs to be replaced.
And now the good:
1. Game was completely torn down and cleaned, see pics of what was done here:
http://gallery.metahugh.com/main.php?g2_itemId=15562
2. All new coil sleeves were installed when rebuilt
3. The 40 pin interconnect was replaced
4. Power supply was rebuilt
Hopefully someone with a love for the older pins will be interested in it. I'm in Richmond, VA. Asking $450.
And now the good:
