Fudd
have a working pp1 pcb for sale. this board is working 100% but due to how notorious these boards are for failing i'm selling it as is. Meaning no return's if you get it and it doesn't work in your system. i use a switcher in my cab to the test points to get a good +5v so i cannot verify either that if you use your edge connector to supply the +5v that the board will work correctly either, since my connections are cut.
1) original battery is clipped off
2) nvram is installed for high score save
3) sockets are also notoriously crappy on these boards. I've noticed on both my pp1 and pp2 boards that over time the chips will work themselves free and cause problems similar to galaga.
i wanted to make all the above clear so you know what your getting.
price $150 shipped to the lower 48
(screen shots are of actual board and gameplay)
