FS WG 4600 Chassis w/Monitor & Stern Coin Door and CP - Pickup Richmond, VA
Umortal377
Aylett, Virginia
Wells-Gardner 4600 series. Have no clue if it works or not. There was no power getting to it from the cab when I tested it with the multimeter. Comes with monitor, Glass, and the board from the cab if you want to mount it correctly. $30
Also have a Stern Coin Door and and CP from the cab so I am assuming its for a stern cab. I also have all the wiring, Power supply, etc from the cab in the box as well. $30
If someone wants both, can do $50.
Couldnt really test the cab since I couldnt get the monitor to power on and the speaker was not there so I couldnt hear if anything was playing. I know the transformer for the Chassis looked to be messed up so not sure if that was the problem or not. I gutted the cab since it was falling apart. But if someone wants the cab to, they can have it.
