apocalypto
Never got round to using this card, time to clean house. I hooked it up once to make sure it worked and it's been in its bubble wrap packaging since.
Looking for $40 shipped. Comes with a 5 Pin RGB Cable and a 2-pin Power Cable
The VGA to RGB CGA Converter can convert a VGA signal to CGA signal. This allows you to play high resolution 31k arcade games on a CGA CRT monitor (15k) or any TV monitor (using AV/RCA or svideo connection, can accept both PAL and NTSC outout). With the help of this converter, you do not need to upgrade the monitor of your old arcade cabinet specially for new arcade games. Furthermore, You can use the VGA input of the Converter to play PC games on a CGA CRT / TV Monitor. That means you can build your own computer-based arcade machine easily.
Features:
Supports VGA/SVGA/XGA/SXGA (640x480, 800x600, 1024x768, 1280x1024) signal input
Supports VGA output by pass
CGA signal output (15k)
Video/S-Video output
Supports NTSC & PAL
Supports position control and zoom control
True digital 24-bit A/D converter for true 16.7-million color conversion
English OSD Adjust menu
Specification:
Power: DC5V 2A +/- 0.5v
Input VGA Signal: 640x480@60/72/75/80/85 Hz, 800x600@60/72/75/80/85 Hz, 1024x768@60/72/75/80 Hz, 1280x1024@60/72/75 Hz
Output CGA Signal: 480i@60 Hz
Output VGA Signal: Bypass
Output Video Signal: 480p NTSC/PAL
Output S-Video Signal: 480p NTSC/PAL
User Control: Output Switch, Image Zoom, Image Position, Output Adjust
Dimensions: 10.5x7.5x1.5 (cms)
Features:
Supports NTSC & PAL
Specification:
