Teknotoyz
I had posted this as a part of "Machines for sale" type thread, but am hoping to move it a little bit faster now that some of the other items have sold.
I have gotten it at the garage door (from the 2nd story) so it is ready for a fast load!!
Re-checked it out after moving it, here are some details:
-98% working, one coin slot doesn't give credits, will check more when I get time.
-Still has an original solid base, taito cabs are notorious moisture magnets and the base is made of MDF. I actually have some plywood scraps I was saving to remake the base, doesn't need it, but the plywood is free if you want it.
-Monitor has a great picture (WG4900), but does have minor burn. Upstairs it gave me a bit of magnetic color, thought it was in need of a cap kit (likely just needed degaussed), but once downstairs the picture looks great. Wonder what I have in the walls up there??
-Side Art is good with scuffs and scrapes as would be expected.
-Lock mechanism is missing from the back door, a long cam lock would do.
-while I would say it doesn't have moisture damage in the traditional sense, it does have "fuzzy" corners on the bottom... pictures coming.
-Everything else looks good, crappy Taito linear supply was replaced with a switcher.
-All controls work as they should, new white buttons.
