FS : Soul Calibur III Arcade Edition Kit
micksimmonds
Donor 4 years: 2011, 2013-2015
UK, United Kingdom
Fully working and tested System 246 Kit, with JAMMA IO, Comes with Soul Calibur III DVD & Dongle, Marquee, Instruction Card, everything needed to fit into any JAMMA cabinet, Played it and no room for the cabinet so this has to go :( $325 shipped within USA
Keep in mind this is a Med res game, so make sure your monitor is compatible.
Also, It might help to post the version of the SC2 DVD (VerA w/ time release chars or VerD [or was it c?] with everyone available right away)
Good luck with the sale!
nope Std Res, came out of a Simpsons JAMMA cabinet, I believe you can switch the Res via the dips? but at present running Std without issues, Ill have to dig out the SC2 stuff, I want to say ver.D
Ill have to try that then, I havnt tried to run the 246 on anything besides the med res that came with the SC3 cab that I bought.
I just looked up this page :
http://guru.mameworld.info/system246/index.html
Switch 1:
On - Test Mode
Off - Game Mode
Switch 2 (RGB output level, set ON if the picture is dark):
On - 0.7Vp-p (use for 31.5k monitor)
Off - 3.0Vp-p (use for 15k monitor)
Switch 3 (Monitor horizontal sync freq):
On - 31.5kHz
Off - 15.75kHz
Switch 4 (Video sync signal):
On - Separate
Off - Composite
Tons of useful info!
the JAMMA I/O adaptor brings it down to Standard Res.
For VGA you would just plug the VGA right into the box straight.
